Logik portal - inference nodes
Hi everyone,
I just installed logik portal on my flame.
I want to download the inference nodes. However where are they to be saved?
I would like to install them in /opt/autodesk/shared/… so that I don’t have to reinstall them when I change the flame version.
Any ideas?
Cheers
Deepak
Hi, you can download them to external drive or on a network path.Extract, add a bookmark in Flame and you are good to go. It really doesn’t matter beacause their “installation” is just copy paste in a convinient folder.
Hi @AntonisNtelis thanks, what do you mean by extract?
I downloaded ESRGAN_4x and in the folder there are two files, a json and onnx file.
Are these to be used as is?
I have downloaded them directly from dropbox folder and were archives in .tgz format.
https://www.dropbox.com/scl/fo/g6ekg9wpdfxbkfkj0zpbm/AGNhEZkl9Xshv770GuVVM0s/Inference%20Nodes?dl=0&rlkey=f3ud7chqsbcnvqqdai2nngyf2&subfolder_nav_tracking=1
Oh, I see what you mean. I downloaded it through the logik portal within flame
Thanks so much.
