Longform playback issues
I know this discussion has been brought up in the past, but has there been any developments in Flames ability to playback long form media without caching or proxies? Loading a 1.5 hour Pro Res in Premiere and Resolve with no issues, and Flame cant even begin to play it back. I am running Flame 2024.2.1 on a Mac Studio Ultra with 128 G of Ram, with 25Gb/s Nas connection…same as Resolve and Premiere. WHY is this an issue in 2024?
There was apparently an update that fixed this issue but im yet to experience an improvement. I also thought it was a linuyx only issue?
I will say this was playing back EXR sequences and anything above a 422hq prores.
It is extremely frustrating
Has there been any updates on this issue? I just restored an archive on a MacBookPro (OS 13.5.2, 64GB ram) with Flame 2024.2.1 and whenever I hit play on the timeline, nothing happens except the Mac’s beach ball spins.
It was the audio. After replacing the original audio file, it plays.
Happy to hear you have found a workaround for your problem. Do you plan to open a support ticket and provide content so we can have a look and solve the problem?
This one is a good old user error. In the confirm tab, I noticed all media was pointing to its original location. Since I restored this archive/project on a different computer, nothing but renders were shown/linked. After relinking, it was all-good.
I believe there’s a setting for archiving media to link to new location—I have look into that.
I also wish there was a way to stop Flame from looking or processing (or whatever it’s doing). Something similar to how Avid allows you to stop a function by selecting command period.
Thanks for the update! Before restoring an archive that have been made on a system with different media path, make sure to enable the option Use Local Path in MediaHub/Archive prior rstoring the archive so content can be decoded using your local access or using Path Translation.
Thanks Slabrie, I’ll definitely try that.
Hi @Slabrie ,
Does the “Use Local Path” matter when archiving a project?
The “Use Local Path” option is only used when restoring an archive. So, if you have defined a path translation so content can be relinked based on your local path, you need this option set before restoring.
