Hi All,
I have a full up media cache destination disk mid project and i now can’t render anything which is understandable. It’s mostly motion vector cache as i havent cached my rushes only linked to them.
What should i do? Should i start a new project with a different cache destination (larger disk drive) and wire everything across. Can i maybe go into the folder itself and delete the motion vector files as there pretty easy to spot. Is this dangerous?
Not surewhat to do. Any advice would be greatly appreciatted.
TIA
Marcus
Hello @Marcus_M
The Project Cretation documentation explains how to modify the Media Cache location of the project:
It is not possible to modify the location of the Media Cache of an existing project from the user interface. Modification of this location is an administrative task and should be carefully performed to avoid data loss. See Media Cache for more details.
If you are not comfortable with command line, you could create a new project pointing to a larger Media Cache and move your content.
Many thanks. I think ill create a new project. I looked at the commandline option and a bead of sweat ran down my forhead and i came over a bit wobbly.
