More Reference Monitoring Possibilities with AWS CDI | December 2022 Update
Howdy Logik,
Flame now supports AWS CDI.
With AWS CDI support for high-quality, low latency reference monitoring on AWS instances, you can achieve improved collaboration & accelerated creative reviews and approvals.
Learn more about the update:
Flame 2023.3 Release Notes
Flame 2023.3 What’s New
Flame Timeline
Update to Flame 2023.3 in Autodesk Account
SO to @gizmorivera for the great shot.
thats between 2 aws instances however as I read it obv not back to your home, i wonder how that will be working in practice.
Using some open source tools I can get a color accurate 4K broadcast monitor signal, glass-to-glass, office-to-home of about 16 frame latency. Could probably get that to 14 frame if I eliminate the cloud relay server.
Any tools you’re willing to share? Jus started my search on what is out there.
UltraGrid on GitHub combined with SRT
Ultragrid is the way for like the most badass DIY alternative to stream flame from A to B hands down.
Also take a look at nimble streamer as a more easy to deploy and more friendly to clients as its easy to throw on a website, I get around 1s or so end-to-end latency with it and its easy and lean. ultragrid is more point to point
You can do point-to-multipoint using the “reflector” capability with UltraGrid. I’ve scripted up a nice little system that uses a cloud VM as a reflector/relay for this purpose. So single stream going out of the office, then the cloud bounces it to all the recipients.
Nimble is great if you want to stream into a webpage. If you want to stream output to HDMI/SDI or as an appliance, UltraGrid.
jup exactly.
