For anyone interested I put a new script up on the Logik Portal and Github. It allows you to use Nano Banana from within Flame. It can be run by selecting a clip in the media panel(It grabs the first frame) to prompt on an image, or select nothing in the media panel to start with an empty prompt. It requires a Nano Banana/Gemini API key.
Sweet! Gonna be a big time saver. Thanks, can’t wait to try it out!
I know Nano Banana is top tier right now but could this be adapted to use an open source model?
Yea, I can look into adding something like that. Might be doable going through Ollama.
Hi @MikeV thanks so much for making this. I see it’s only for 2026.2 and up. Is this a limitation of flame? Is it not possible to work on 2025.2?
Hey @johnt it might work in 2025.2. I just have it set to 2026.2 since that’s the only version of Flame I have installed right now for testing. You’ll need to change the minimumVersion to 2025.2 at the bottom of the script to get it to show up in 2025.2. If it works let me know and I’ll update it on the portal.
I’ll give it a go in the AM.
thank you
Amazing ! Thanks for developing this @MikeV ![]()
Did you have any luck on 2025?
Thank you
I just did a test of the script in 2025.2 and its working. I just uploaded a updated version to the Logik Portal.
Thanks @MikeV
Amazing!! You’re a legend, Mike!!
Just curious what people are doing with the images submitting to nano, I am in aces or Log , do you convert to 8 bit Rec then submit for prompt? I notice when I submit it changes the color values and curious what peoples work flow in terms of keeping color close.
