The title says it all. I have a nice key but I want to keep some parts of the image. It’s real easy to mask the areas I want to keep because I have a tracked camera.
We have all the blend modes and matte composition and correlation, but can’t make sense of it.
On a related note, is it possible to make a mask to just subtract from another one without affecting the matte?
I think using different outputs will give you what you’re asking for. It works just like in Action. You can use Alt-E to select/de-select which masks you want to assign to an output and then you can use Comp nodes to Multiply/Add/Subtract the mattes how you want.
