Segment Markers burning into following shot
When I add a segment marker to a shot and then use burn in metadata to display the note, the burn in still displays on the first frame of the next shot.
Is this a known bug in 2025? Is it fixed in 2026?
Hello Leo,
This is a known issue on our side and it should be fixed in an upcoming release.
OK thanks. Please hurry. I need to get a WIP out :sweat_smile:
@fredwarren I also noticed that when you sync segment markers to other edits from the Shots Sequence they land in there untrimmed if the shot is shorter and is the first shot.
