Shot Sheet Maker - fails on xlsx writer
For anyone intersted, I’ve added a new version of this to the Logik Portal. You can now select multiple sequences to create shot sheets from. I’ve also added a button(Create One Workbook) that will create one spreadsheet file that has each selected sequence as a separate worksheet tab. As well as fixing a problem with the script working properly in 2023.1.
Mike
How it is possible to make the shot name as a separate column instead of a line, and to separate shot length in 00:00:00:00 from in Frames
Best regards
If you click on Edit Column Names you can select the different types of clip info to create a separate column for.
Hopefully that does what you’re looking for.
Mike
I want to rebound on the possibility that instead of creating floating thumbnails the images on cells, it can embed them inside the cell which makes navigating, hiding, deleting or adding rows much easier :slight_smile:
Hah… never noticed the images weren’t part of the cell. Thanks for pointing that out. I’ll see what I can do about that.
