My first question on the forum…
Is there in Flame any tool to auto-reformat like PremierePro has? Social media is driving a ton of attention and versioning is exploding so these kind of tools would be great.
Any pointer?
Thanks in advance.
Nope. And…at least at the levels I work at, clients care enough about social framing to want it done with intent rather than just yeeting it through an automatic tool. We make figuring out all that stuff the offline editor’s job. Well…it’s usually the offline assistant’s job if I’m being honest. Doing it that way also means we can bill for it. $.02!
Most socials I make have completely different title treatments for all the aspect ratios. I also, (sometimes matching an offline, sometimes just doing it on the fly myself) adjust every shot, not just in X position, but scale as well, since I am generally using footage at native rez. There is rarely a one-size-fits-all situation.
There’s no one button solution for this. The main thing I’ve found is this: Doing a reformat on the sequence can be unpredictable as to how it will treat resizes from the original sequence. So I will make a new blank sequence at the social resolution and then copy/paste the original content into the blank sequence. With “Crop Edges” resize you should see everything as you expect and you can pan-n-scan shots as needed.
On top of all of this… if you are using connected conform… using Reformat will break all of the links between segments. But if you copy/paste like above you can maintain the connections.
There’s a Logik Live episode where I walk through my process: Logik Live Episode 11: Connected Conform with Bryan Bayley - YouTube
Thanks so much Brian, will check the Logic Live Episode.
Hey hey howdy hi Jordi. As others have stated, the live action framing is the easy part. It’s all the other stuff that goes with it…supers, legals, end cards, subtitles….these aren’t deliverables, these are custom spots where the only thing that IS the same is the live action. So, whilst the Adobe Sensei looks cool, it automates the easiest part of a complex problem.
Very true, I should not treat them as versions but as different spots altogether. Thanks once again.
BTW, we are dropping Hiero and NukeStudio and moving all our vfx editorial work to Flame so you will see me here quite a bit. I hope I don’t ask too many stupid questions.
There are no stupid questions.
Hahah totally. We didn’t create the forums to not ask questions.
We created the Discord for that. :-).
That’s great news!
Perhaps I should share a bit of what we are doing to give you some context, I am sure you will like it.
We have been testing for more than 1 year Flame on AWS and with the very latest version, which arrived 2 months ago or so, we are so happy that we are as we speak adding Flame into our pipeline, integrated fully with NIM (our task management software) and Nuke script generation.
We have been working on the finishing and versioning with flame for almost 2 years, but now we moving all our main compositing pipeline to Flame and having Nuke for the CGI shots.
We are also starting to mix Flame on those shots and I think in time we will be in a position to be able to choose between Flame and Nuke based on the job and specially, the artists doing the project.
So, at this stage, we are full steam ahead on this.
BTW, our RnD and pipeline guys are very impressed with the work done by Autodesk on the python side of things and all the workflows…
Good times ahead.
PS. We are always looking for senior artists so if you are interested in working with us on some cool projects, please DM me, would love to hear from you.
cheers
Looking back at that Logik Live from two years ago I can see a few things I would update for 2022. I will try to do a new version of that.
Updated Connected Conform Logik Live?!?!?!?
Let’s do this.
Jeff - I know you have some different approaches. Should we do a show where we discuss pros and cons of each?
That sounds like the makings of an excellent episode.
So good to see you here @jordibares !
Please ask us anything!!
I wanted to follow up on this Auto Reframe query… I have been testing Resolve one and it is truly well-crafted, easy to alter and very predictable.
Autodesk, this is a major issue for us as many of our client’s deliveries involve at least 3 aspect ratios and doing it by hand is very very time-consuming.
If there is any way to prioritize this, please do as sooner or later it will become a dealbreaker when doing deliveries, not just for us, but everyone.
Thank you
intersting that you find a need for this, i am in the same boat as most others here, where it takes me maybe 15 minutes to reframe my sources sequence to each social format with intent.
its super quick, if you work with connected conform.
TBh the most annoying part is that we cant reformat our sequences, if we could just do that that would be gold and save so much time, biggest waste is me having to copy each timelines contents into a new timeline with the right resolution - ugh.
I find that even if the process were “automated” it wouldn’t be much help. Every spot is different, a lot of shots need individual attention since a standard crop/fit doesn’t yield satisfactory results, and most spots need a separate set of titles. I would be happy if you could reformat a timeline without reformatting the footage or losing the connected segments or changing the aspect ratio of masks. It would also be great to be able to ripple the changes through versions with the same aspect ratio without screwing up the original. It’s possible, (I think I demo’d it once) but it’s a big song and dance.
One great AI application in social formats would be to be able to “extend the image up or down” and keep it temporally stable. How many times have you used the extended bicubic surface in the TL action to stretch the top of the image to cover the 9:16 frame?
