Hey friends, I’m getting some weird hilighting in the softness of some gmasks. I can’t seem to track down where it’s coming from. I imagine someone here might know exactly what’s going on and the proper button to push to make this go away?
This looks like an unpremultiply error. The edge pixels are getting divided by the values coming from the gmask as if they had been multiplied by the matte. If they haven’t been multiplied by the matte then there is no need to do the unpremultiply (divide).
Are you doing the comp in batch? Using an action node or a comp node. Can you share a grab of you schematic?
I suspect you are using action. Most unpremultiply techniques are quite explicit. Action is a little hidden away inside of the surface settings.
Select the layer inside the Action schematic.
Go to the Surface menu.
Look for the Blending column or the Alpha settings (not in front of the box atm)
You can toggle the setting between Premultiplied and Unpremultiplied (or “Straight”). If you are getting dark or white edges, ensure this is set correctly to match your source material.
If you can rule out premultiplication errors, then I would attribute this to a known bug that can present similarly. It can usually be resolved by pre-rendering your mask.
Yes, working in action. I tried toggling the premultiply button. Super familiar with that setting… Sorry for the messy scematic! The funny thing is I think I fixed this on one of the other comps but for the life of me can’t remember what I did…
So this might help two birds and one stone- I would do that restore roto (surface 2) outside of the action in just a gmask tracer. Gmasks in action slow you down and with your selective and stuff happening in there I wouldn’t be surprised if somehow that’s busting some premult thing.
I’m not here to tell anyone how to comp, Flame is very flexible, me personally, I’d go about it something like this though. The part that really might help though is the BasketRestore happening outside of action. So the order being, BG Plate, Dog, Basket over top )the comp action is just layering things, only premultiplied surface is the dog). I 100% don’t want to sound condescending by the way!! Just a thought about things happening in action or outside, totally personal preference though!
