Using Path translation or changing File Location in XML
Been trying to do both on 2025. In File Location in conform I can’t select multiple events unless I do a ctrl A to select all. Not what I want.
In Path translation I see no difference. XML looks the same and I still have to scan to find clips that should be reflected correctly with path translation.
Path Translation wouldn’t change the XML; it’s like a symlink for media Flame already has.
You could open the XML in a text editor and try doing a find-and-replace with the old path for the new path.
-Ted
Will do. Thanks
