Anyone know of a way to have an xls with say column of names and another with the timecode and then translate that to something flame can read and cut up based on that data, ie a reverse shot sheet maker that @MikeV has made up but instead of generating a xls you use that data in flame? Ideally would just want to name the clips and edit the clip.
This sounds like a job for Python.
You’d probably have an easier time creating an EDL instead of an XML, though.
-Ted
