2023 woes
So after updating my machine to 2023, I keep getting this in a shell:
io handler error: Interrupted system call
Any ideas?
Unless something isn’t obviously working, I’d ignore anything in the shell like this.
I would definitely not ignore that. That is not good.
Follow up with support…But you might want to see my latest video to choose which one of those guys you should not deal with.
BTW, if the source is soft-imported, that error might also indicate that a source frame is bad. Try frame-by-framing thru the whole clip and make sure it is good. I’ve seen in the past when watching a clip in Player it can sort of “skip” over a bad frame and it might not be obvious that one was bad.
