2027.1 text node
Looks like the GUI is corrupt in 2027.1, can’t get to the edit / move option. 2027 works ok, but not in 2027.1
Same issue in the new type node
That looks like leftover stuff from Action.
But I’m not seeing the same thing here, even if I flip back and forth between an Action and an old Text or Type. Are these TLFX and you’re on the Effects tab, or is this inside Batch or BFX?
Inside batch
Hello Paul,
Like Bob, I cannot replicate this on my side. I tried switching between Action, GMask Tracer, Image, Isolate and Text. I also tried using Context views.
Do you still have the issue after a restart? If so, can you record the whole screen showing your setup and post it here (or send it to me in a direct message).
A reboot / restart seems to have fixed it, however, esc to get back to batch schematic doesn’t work if edit is selected, all other options work ok.
Also pan, zoom don’t work in edit either.
