3d cleanup adding defocus
Hey guys I have a shot where I have camera tracked (flame 2022) and projected a clean frame. The is a focus pull in the shot how do you add defocus to the clean projected frame. When I use freeze frame within the projector I can’t seem to add the defocus
Thanks in advance
Could you output a projector matte and do the focus pull after?
@Justint I asked a similar question here which might apply to your workflow.
Ohh that looks perfect John will have a look once I am in
Thanks
Jt
Freeze the image with a MUX prior to the action/projection and apply the defocus in between the two, then leave freeze frame off in Action.
