3D track - deleting keyframes
Hey Logik,
does anyone know how to delete bad keyframes from a camera analysis? I can see the key frames I want to remove, but everything appears to be linked via an expression, and un-bakeable.
Thanks,
Gareth Parry
I think this is the same issue- 1 frame bump - analysed backwards and it happens at start, analyse forward and it happens at the end
Are you using every frame for the analysis?
every 2 - res is set to 2
cut the link between the analyzer and the camera.
So this could be the problem. Set to every 1.
