Edit Camera Analysis
Is there a way to edit the camera analysis keyframes in the new camera tracking module?
The keyframes are in the Animation, have tried all kinds of commands with no success.
I got pretty good tracking but some frames are out, so I would like to reposition those keyframes manually.
Using Flame 2022.2
Thank you!
You need to cut the link between the analysis and the camera. You should then be able to edit the camera data
Thanks a lot! Saved my day!
Solved!
I know I know … use the search tool first.
I swear a made a search for a similar topic, but I was so in a hurry that I made it with the wrong words!
Thank you!
