Action - Shadow Cast and GMasks
I’m throwing a quick animated action comp together and getting some odd behaviour i am struggling to fix.
I’m using 3d Text with no depth to create the words, a gmask to reveal those words and a Light with Shadowcast node to give some subtle dropshadows.
Problem is the Gmasked and invisible text is still casting a shadow, as can be seen on the screengrab.
How do i stop the Light from ignoring the GMask?
thanks
adam
Screenshot 2021-06-08 at 14.02.10
Two options:
  1. Duplicate the BG that is receiving the shadows and set the duplicate’s “Shadow casting” to “off” (it’s on the surface section, down in the bottom middle), then have a gmask cut through both the type layer and the cast-upon layer, leaving the “shadow casting off” layer below it all.
  2. Build the text in a separate action so the alpha is already animated when coming into the shadow-casting action.
Thanks Andy…it was a variation on your suggestion that i used…two outputs from action, one with and one without, then do the gmask before a comp node.
Had a feeling it was one of those odd gotchas that required more than just hitting the right button.
