AI Grain tool added to Silhouette 2023!
Silhouette 2023 trial is online at borisfx.com
Denoise ML from my test is not on pair with Neat Video quality wise.
Regrain does not work as I`d like in Fusion 18.5 beta, plug-in does not show anything if provide it with more than one input. I could be wrong here - never use Silhouette before). When doing denoise/regrain inside Silhouette results are good at first glance.
Could be a red herring but in the plug-in believe you need to select what is being output from Silhouette… default is the roto node from a default setup, but it might be that you need to select the output node instead?
I don’t use Silhouette—just remember that from some training video.
You have to change Render to “Output: Composite” and it works. Both of the new grain tools worked well on the one clip I tested. Denoiser ML was much slower than Neat though.
Interesting. Thanks @john-geehreng ! It doesn’t really surprise me that the ML Denoise is slow. Particularly in the OFX version.
