Has anyone seen this? Maybe @marcopaolini ?
I wanted to test the new inpaint feature and the result looks pretty good in Silhouette but when I look at the result in Flame, nothing’s there. Even if I do an auto paint after inpaint, only the paint strokes show up.
Ugh. Unfortunately, this is an issue. We will fix this asap in an upcoming point release. In the meantime, you can set a filename and path in the Output node, and then use the Render menu to render to the filesystem. If I can come up with a different solution before the point release, I will post it here.
Gotcha. I’ll use that as a workaround.
Thank you for the quick reply, Marco!
