Received! Thanks so much, Tim!
Yup… everyone can stay up-to-date on the submissions by following this Playlist.
Just submitted a few
Received.
My only access to flame is in a high security environment, so no video from me. Improvements I’d love:
-Some kind of Match grade tool that is better than the curves in the CC. Should also create 3D LUT and/or CDL.
-Tracking that works in scene linear
-MasterK that actually works as well in scene linear as log.
-Player settings that stick after reboot, like loop, in to out, etc.
-Why do I have to ‘mark as viewed’?!
-Bring back maintenance on purchased licenses (we did buy PERPETUAL licences!)
-Multichannel input and output in action without jumping through hoops
-Fix all nodes that don’t filter the matte identically to the front
-Make all nodes handle more than 2 inputs/channels
-Subdivide for ex-bicubic surfaces
-ProRes RAW support some day!
-DNG support since it’s such a rich format, and we’d like to be able to control it inside batch
Give me an hour and I’d have 20 more. Sorry for getting grumpy.
*edited for profanity
this was one of my submissions @SamE - a la match grade node in Nuke. Bring the grump. It’s the only way we change things!
Good catch. There now.
Great list of improvements. You might want to add your vote for the ones already existing on flame-feedback and create new ones
You could add your vote to the ProRes RAW support which has apretty low count these days… See Autodesk Feedback Community
You may already be doing that. Just in case: A relatively accepted technique for Resolve colorists having to deal with inferior keyers is to ‘side-chain’ the key paraphrasing an audio term here.
It’s not always feasible to make each keying algorithm work equally well in all color spaces. But if you know which color space a keyer works well in, create a side-chain where you convert the front input of the keyer to the optimal color space for keying, or do other key prep (increase contrast/saturation, go to Lab color space and key on chroma only, etc. etc.). Then use the matte output from the keyer in the main node flow. That only works if you’re after the matte. If you need the keyer to also despill you need to run the image through the actual keyer un-altered. But even then, use two keying instances - once for the matte generation with all the prep gymnastics, and one on the main line for just despill.
Hey @Slabrie, I’ve been after my company to create an account, because I don’t have an active personal subscription anymore. Is this something I can do directly, as a Supe for a company that runs 40+ flames?
Currently jumping through these hoops.
hi @Francesco.Bianco - i was watching your submission tonight and just wanted to say you can already drag a bounding box to select multiple segments in a timeline without having to be outside the area of the segments: hold CTRL+SHIFT+S and drag away from anywhere on the timeline.
Thanks Tim for the info. I’m on smoke hot keys and by just holding W and drag a bounding box and does the trick. CTRL+SHIFT+S might be for flame hot keys. Anyway, since you can drag a bounding box from outside the timeline without having to press and hold anything, it would be easier to have the same behavior even within the timeline. In the meanwhile i’ll use W. Thanks again.
Hello Sam!
Flame-feedback does not require a Flame license. You can register for free and see the various improvements, add your vote and even create new ones! I hope I did not create a monster by telling you this ![]()
You need an active subscription to be able to access the various builds of Flame Family products and open support ticket.
40+ flames is nice. But 50+ would be nicer ![]()
I might be late, but sent in the shortest request at 12 seconds ![]()
Here’s the breakdown of most requests I covered with either the link to the existing request at flamefeedback.autodesk.com of a demand to add a new one.
@andymilkis @Sinan @allklier @Francesco.Bianco @Ryland @bryanb @ytf @Brooks @TimC @ALan @KuleshovEffect @finnjaeger @RufusBlackwell
On the Radar
These items are on our radar. We are in the process of investigating / defining them.
Keep EXR Metadata
- Add your votes to FI-01250
Colour Coding for projects
Paint on References
- I would mention this use case in FI-02528
Don’t Hold your breath / Issues with what is requested
These have all possible issues (technical or conceptual) that make them harder to implement.
Add Timeline FX Clips to the Desktop
As mentioned in the presentation, we do not plan on implementing this. You can always add requests to improve the Explorer workflow on the Timeline tab.
Add your votes to FI-02342
Camera Analysis Range
- Add your votes to FI-02663
Add/Delete GMask Tracer points from the Timeline / Player
- Please submit a new request. Keep in mind that the workflow with shortcuts probably wouldn’t work.
Animate the selection icon for the Human body selective
Sinan, I tried what you mentioned during the event and realized I could have made a better due diligence on my side. Sorry about that. The widget has Position X and Position Y settings, but they are not in the UI, meaning that you can only animate them with Auto Key enabled or by selecting the channel in the Animation menu (Image → Human_Body → keyers → semantic_keyer → position). From my test, it should improve the use case you were showing.
Please submit a new request to have the settings in the UI.
F4 to cycle through the Colour Warper views
Use the output of Context view as a Tracking source
- Add your votes to FI-01443
Add Grading tools in Paint
Nested Sequences
- Add your votes toFI-02814
Only a matter or prioritization - Simpler
Nothing prevents us from doing these. It is only a matter of prioritization.
Do not reset Pivot in GMask Tracer until the Edit Box is turned off
- Add your votes to FI-02603
Drop on top of existing clips in the Freeform view
Select multiple corners of a Perspective Grid and move them at once
Have a keyboard shortcut to go to the bottommost Timeline track
Move windows (like Media Export) outside of the screen
- Add your votes to FI-01282
Add an Effect percentage in the Colour Correct / Colour Warper
- Add your votes to FI-01040
Copying a TLFX Timewarp to keep its Timing info on the new segment
- Add your votes to FI-02208
Link Zoom & Pan in multiple viewports
- Add your votes to FI-00400
More filtering options in Broadcast Monitor / Scale to Fit
Have a Setup/Custom option in the Batch Cache Range
- Add your votes to FI-03097
Invert the matte output of a 3D Keyer
Expose Text controls in the Timeline FX Ribbon
- Add your votes to FI-01904
Editing Smart Tool - One mode with Trim, Slip, and Slide.
- Add your votes to FI-01409
Limit a the visibility of a GMask to a Range
Only a matter of prioritization - Harder
Timeline Total Transparency / Replace Background
Create a LUT from the difference between an ungraded plate and a graded plate
- Add your votes to FI-00475
Make other Keyers than Diamond in Image Selective
Have a Hue Diagram in addition to curves in MasterGrade
Make the Perspective Grid’s Width/Height setting editable
Create a link between Render node and a Clip node
Arnold Rendering for Flame
- You may want to add your votes to FI-01640 which is a request for ray tracing support or submit a new request for Arnold.
Already Possible
Modify X and Y proportionally in Colour Warper’s Blur
- Add your vote to FI-00856 to have a button in addition to the Alt-Shift-Click keyboard shortcut.
Already Kind Of
Cycle through Paint Source Input with F1
- Please submit a new request to see the workflow I showed being improved.
Onion Skinning in Batch Paint
Changed the order of Colour Management and Resize in Pre-Processing
BFX Mimic Link
Other
I didn’t understand that request properly. Could you please further explain the problem you are having.
- Combine to process a result with 2 Inputs only
The list I posted only includes the requests I covered, not the ones from Stéphane.
