I added an alternate track to 3-4, set the outputs on the audio desk to 1-2, muted the tracks on input 1-2. When I played it down I heard tracks 3-4 correctly and nothing from 1-2. When I exported an h264 with no mixdown, I ended up with the audio from tracks 1-2 and nothing from 3-4. Bug or feature?
I did some testing and found this behavior consistent across several formats including pro-rez. If the audio export is set to Mix Down As Is, it works correctly. @Slabrie is this expected behavior?
Maybe because you routed 3+4 to 1+2 in the audio mixer. Try leaving 3+4 to 3+4 and export with no mixdown.
That just exports to 3-4.
Please open a ticket with our Support team so they can investigate the issue.
