Baselight on Flame
im thinking of getting the BLG software for flame as im working more and more with baselight graders again - seems to be a swing back to that. anyone using the BLG workflow?
I’ve used it years ago… it worked… if the colorist hadn’t used external mattes, plugins or otherwise ā€˜weird’ stuff. Maybe that has improved by now, but back then it made us stop using it. I’d make sure to test various scenarios like that before purchasing it for Flame.
Still has the same limitation as @Ton mentioned, so no external mattes/grain/images other than the plate itself obviously.
The other caveat is it’ll only be able to render the frames/timecode that it knows so if the grader didn’t expand the handles when they exported the BLG then it’ll error out on those frames.
Finally, it’s beyond slow and acts like a little princess. Sometimes it takes quite a few tries of stopping/starting the renderer, reloading the BLG, F1, F4, rinse and repeat before it decides it wants to play nice and start, you know, actually applying a grade.
…buuuuut it sure is nice to be able to just apply a grade or see a comp in context.
We last tested it maybe like three or four years ago. Never mind weird stuff, it didn’t even work carrying over basic tracked shapes (weirdly aka power windows) for us, which stopped us using it.
Which is a shame, as virtually all our high-end jobs are a Baselight/Flame collab.
$0.02 - It’s less problematic to exploit a flame centric open clip publish and subscribe workflow, and have the graded material just be a version.
Hi Jon, we are regularly using BLG’s here, they work pretty well now although no matte inputs etc and yes the rendering is a bit slow but fine.
Yeah, there was a bug some time ago where the shape wouldn’t track if you either selected a single BLG or had it find the BLG from a folder (forget which one). As far as I recall, that’s been fixed.
doesn’t sound like its worth it. its 2k a year. just for a glorified LUT! I will skip!
The Resolve OFX plug in seems to be working pretty well on the tests I’ve done so far
That’s because you’re on Flame… for anything else… it’s free…
It does… except you have to manually load each grade per shot, no?
yes, you do have to load them one at a time
There’s a resolve plug in???
yep
fell free to DM or call
A… too bad. I had hoped I overlooked something. Hope they address that in the near future, would be awesome.
it’s an improvement on the first version where you had to cut and paste the file location into the comments field!!!
The difference though is if you are solving a pipeline issue (get non-LUT grades from colorist) vs. you just don’t like Flame color and want to do color in a different app. Different scenarios.
The Resolve OFX is obviously undergoing more active development than the knee-capped BLG plugin. But it too may have some issues - namely around tracked masked and how they translate in terms of TC. And presumably will have the same issues with external mattes, etc. though I don’t have specific test results.
Any headless plugin is facing an uphill battle. With BLE for Avid & Nuke, at least you get the full Baselight tool (minus a few features like grain/paint/etc) and can fix things that didn’t come across.
It cant deal with ā€œtimeā€ so any animated mattes arent going to lineup,
a bunch of other stuff isnt working as well, its more like a tech demo.
@finnjaeger - yep, sorry about that. I quit before it was finished. Evidently it still isn’t finished. Too bad - it could have been a good thing.
