Before NeatVideo we had Compound
I still use compound and it is amazing but what is it doing? How do I replicate that in Nuke?
Are you saying you want more info than that?
Yeah. Thanks for the response.
How come it doesn’t additive get brighter. How does it combine those frames.
I love it but can’t get the Nuke team to recreate because I don’t understand.
Sorry, dumb joke. Just one example of the manual being… less than illuminating.
I didn’t realize how little I understood compound until I was talking it up to someone a few weeks ago, and that’s after using it for 20 years.
If you do figure it out, please report back!
Adding… I suspect it’s some kind of temporal averaging. If I were near a box I would try average+timewarp and compare the result. Alas.
Oh yeah. Durrh!
Average over 20 looks just like compound over 20. Now you made me feel stoopid.
Whew! It was a lucky guess! Possibly fueled by beer.
I use it constantly for clean frames. I replicated it in Nuke once without knowing about average. Let’s say you want to go over 10 frames, you add them together and then divide by 10. I forget if it was a math operator or just in the grade node.
so what is Compound? I’ve never used it, but now you have me intrigued!
So it blends any number of frames, user editable, into a single frame. So if you can stabilise a shot or the shot is static it combines a number of frames and all of the grain/noise blends together and cancels its self out.
A lot like average (apparently) or recursive ops.
Unlike average or recursive ops you don’t need a run up on the sequence to get the blend. It sort of looks ahead and will blend all of the x number of frames for you.
If you compound over 5 frames your clip will contain one fifth of the frames and those frames will be a combination of 5 frames each.
Give it a try.
Thanks…vaguely remember a similar tool in Shake 15 yrs ago!
Definitely use it. For clean plate work it’s indispensable. Essentially it’s a uniform temporal average of the number of frames entered in the box. Other than used as a degrain for creating clean plates, use it for averaging out any changes in quality to a stabbed or locked off image—especially useful when you planar unwrap.
In Nuke the closest to Compound is FrameBlend with startframe and endframe set. Without it it takes a numframes and then it works like an Average (i.e. it has a midpoint with falloff, and the midpoint will be your falloff).
I use Compound (and FrameBlend in fixed start/end mode) all the time :slight_smile:
Temporal median node in nuke does this. (never used compound though)
