Blanking Edge detector
Hi All
For that knotty problem of checking blanking (especially masters with letterbox) I made a little gap batch fx setup. It’s only been used on adverts but seems to work quite well. I’m sharing it here in case it’s of use to anyone.
(The 2d transform on its own could be used for masters without letterbox)
John
LETTERBOX_EDGE_CHECKER.zip (73.7 KB)
Genius @johnt
It works very nicely. I was actually looking for another solution but yours popped up first.
Someone was explaining a matchbox I had not used/heard of called id_Edgy
I combined your 2D_Transform and id_Edgy so that now any bad blanking screams out at me in garish yellow :+1:
I’ve done the same. It’s a pretty good combination!
If you guys are looking for something more automated to check for blanking. I wrote a python script that will do it for you. Let me know if you’d like me to share it with you.
Absolutely @feganflamer
that would be great. Thanks for the offer.
Perhaps you could add it to the portal
Right now It doesn’t work in flame, just the shell. You can only qc one video at a time for now. When I have time I plan on adding the ability to add folders with multiple videos to the qc, as well as a gui.
Installation:
You need to “pip install opencv-python numpy” then run “python3 qc_blanking.py /path/to/video.mov”
the output should look something like this.
user@host:python3 qc_blanking_check.py /DL/video.mov
Video Info:
  Resolution: 1920x1080
  FPS: 23.976023976023978
  Total Frames: 720
  Duration: 00:00:30:00
Analyzing for blanking (black threshold: 10, edge pixels: 5)...
BLANKING DETECTION REPORT
Video File: /DL/video.mov
Total Issues Found: 0
No blanking issues detected!
qc_blanking_check.py (8.1 KB)
@feganflamer send me the python by email when you are able
