Having some issues with the camera tracking. losing the cached source all the time. anyhow. when I select a tracker and add 3D text objects. how do I then turn those objects into real axis so I can attach things. basically I woant to select a trader and make an axis. I can make a plane - which is never in the right plane anyhow. I just want to select a tracker and put an object there??
I mean the 3d test objects!
Select the Tracker and then click on the Scene Trackers button in the Object Tracking section.
For more information, yo can have a look at the videos Grant has made for the Flame Learning Channel
ive done that and the axis is no where near the tracker.
