Centralized presets and shaders and python
is there a way to centralize all these components across a studio? I am getting a bit mad copy pasting export and python stuff across all my machines.
easy as to symlink the required folders to a nas location or does it need something special?
ok i am stupid
https://help.autodesk.com/view/FLAME/2025/ENU/?guid=wn-2025-central-components
You will want to run 2025.1 to make it even easier.
Using the Same File for all Application Versions
There are two methods for using a single sysconfig.cfg file for every version of the application on a workstation. In both cases, new features added to the sysconfig.cfg file in future versions will have to be manually added to the centralised sysconfig.cfg file as it won’t be automatically updated by a new application version installation. These methods are:
  • Save a sysconfig.cfg file directly in the /opt/autodesk/cfg directory. This file takes precedence over the file located in the /opt/Autodesk/cfg/.<version> directory.
  • Set the DL_SYSCONFIG_FILE environment variable to a centralised sysconfig.cfg file path.
thats super nice and supr easy, love it!
