Converting graphic to Sony log3 for comp
Hello, I have a graphic lottery ticket I need to comp into my shots. Since I grade and comp myself, normally I would grade and then comp something like this. This time I need to comp before color and I’m trying to figure out how to use the color management node to convert the JPG first. I am using the color management node to see what I’m working on as a context view of the Sony footage and comp - however converting this JPG from the agency I’m having trouble with! Thanks so much for any insight!
Video footage is Sony S Log3 Cine. I was going to leave it as is and have been viewing through the appropriate LUT using color management node and then bypassing the node with the LUT to send back to color.
I just put a view transform on the graphic, MyCamera to Rec709, then invert it.
Thank you!
