If you save the text setup and then go to the other node and load… choose “Multiple Text Setup” and it will load the saved one and keep what was already there.
Thank you very much bryanb for this advice. It works very well
One questions remains: Is there a reason that Flame does “suggest” to save this text-setup under /opt/Autodesk/project? Or is it the same if this text-setup file is beeing stored on an other volume (in my case on an external SSD)?
