Crazy Idea - shared Flame framestore over Thunderbolt Bridge?
Im seriously considering buying a 2nd Flame but I want them to use the same framestore. A 5 banger 10Gig switch is only $350 these days, so I could access it over the network…but, what about using a Thunderbolt Bridge? I’ve set this up using Sharing before, but never for a framestore. Theoretically it should be fast and slick, right?
Anybody else ever tried this nonsense?
Aight, I just turned on the JFP signal. We’ll see if he bites.
Asking for a friend, but why would one person need two flames?
To be able to run 2 flames at once. :slight_smile: :grimacing: :man_facepalming:
Seriously. I’m looking at ways to tag team projects, and want all the data in 1 place, with a Flame friend controlling a Flame via Teragucci.
I love Xsan, and I believe it’s still supported. Keep in mind that the storage has to be really fast to keep up with two users.
Last summer I priced out a Fiber Channel array that accepted 24 SSD’s. Would have been sweet, but the big project didn’t materialize.
Without a switch you could have a single user with 12Gigabyte/second connection, and two users with 6Gigabyte/sec connections.
Or splitting 10Gbps x4 NVME RAID0 sticks would work… :slight_smile:
Engineer here! Yes, this will in theory work. As long as two machines can communicate over any means you can share a framestore.
Most people go with 10Gb because of price and scalability.
You could just do direct connect between 2 network ports of any type, 10gig,25gig, etc. No need for switch.
