Create Export Menus
I’ve done some updates to this script that now allow you to assign up to five different export presets to a single export menu. You can also rename/edit/delete menus after you create them in the Edit tab.
Available on the Logik Portal or here:
Mike
Duuuuuuuuuuuuuuuuuude!
MVP.
Well done
Thanks. What I lovefrom this script is export using several presets simultaneously . One of my big hated taskes is export and reexport and reexport one clip to diferent delivers request (prores/h264/with or without letterbox, scaled not scaled … etc).
Mike you’re killing it. Thank you!
Very good Mike, impressive work. A suggestion in a next update, would it be possible to add sequence publish presets? Thanks.
Yea, I’ll see if I can add that on the next go around with this script.
