Create holograms
Hello everyone,
Soon I will have to generate some holograms with a texture similar to the one you can see in the attached photo.
In other projects, I have already had the opportunity to generate holograms with other types of textures. By mixing several Flame tools with some Matchbox I have managed to get a good finish but I would like to know if any of you have had to generate this type of texture in a hologram and how you have done it.
In my opinion, the most complicated thing is to generate those particles that hermit the characters converted into hologram and the grainy texture.
Thank you very much for your help.
Text
Give my tutorials as well as episodes of Logik Live1, Logik Live 2 and Logik Academy. Hit me up if you need some help with a specific thing on particles.
Also try atomize in action with a displaced surface. With a low setting for the surface resolution (below the surface filter box) which will give you a higher number of atoms. This is a very fast way to create particulate looks…
Thank you very much, Sinan.
I’m going to do some research to see if I can get something interesting.
