Deform mesh on top of Deform mesh?
I thought I heard someone mention that it’s possible to have a Deform on top of a Deform in action, but I’m having no luck. Is this actually a thing, or am I high? (don’t answer that)
Loving Deform now for beauty reshapes - thanks for tips on this, whoever that was.
You can’t apply two deform meshes to the same surface but you can combine them using UVs. Apply the mesh to a UV in action then pipe that UV into another action and continue warping with another mesh. Then apply the UV to your image. Make sure to keep everything 32-bit.
You can also use bicubics on a surface with a deform mesh to warp an image twice within the same action.
Thanks Ryland.
