Where does one go to delete any/all instances of an iteration. Last night, I deleted several iterations from the Iterations folder in the selected Batch group. After looking in the library, they are still there. Seems I’m missing a crucial step here.
You’re doing it correctly, there’s no other way than manually deleting them.
Maybe you only did it in a Batch group in your Desktop and forgot to save and replace it in the library?
Another option might be python? (I haven’t used it yet)
Yes. There’s a sample python script that ships with flame that will delete all but the latest iteration. You can find it in /opt/Autodesk//python_examples. It’s the file called “clean_batch_iterations.py”. Just put it in the /opt/Autodesk/shared/python folder and rescan your python hooks (cntrl-shft-P-H) or relaunch the software. It should be available if you rt-click on a batch group.
