Curious if anyone is bothering to set their monitor refresh rates to 48hz on Linux. Ignoring the hires tolken used to be something you had to explicitly set but now without video preview out on the Aja the token is ignored…
…and please feel free to insert 50hz for those of you who have always had an intelligent standard.
I run at 60hz, I’m pretty sure it’s at the mercy of what your monitor is able to do. If you terminal then type nvidia-settings on the x server display configuration select your monitor , then select resolution to other than auto to the right should see your available refresh rates
Of course, or xrandr works a treat. My curiosity was more about how people feel working in a frame base not sync’d to the playback FPS…
Guess it’s not a thing.
