I just had my system upgraded to 2025.1
Which means I had to install rocky linux
My monitors have come back reversed
How can I make it so the library section is on the left monitor and the timeline on the right?
Thanks in advance for al of your knowledge.
Switch the cables. ![]()
Or.
Nvidia-settings in a terminal.
Thanks. Nvidia controls did the trick.
You can also use the Settings app and select Displays and define your monitors configurations. You can also define the Primary display, the resolution, scaling factor, etc.
Less scary than nvidia-settings and does not require admin privileges.
