Dynamic Naming doesn’t seem to work with pattern browsing and connected conform.
I set my tokens as:
<source name>_<source version name>
and turn on dynamic naming.
This gives me segment names such as “sh0010_comp_v001”
Great so far. I can version up and down this segment and the name changes in line with the version number.
However if I jump to a connected segment in my shots sequence, I can see that although the version has changed, the name hasn’t. If I adjust the version in the shots sequence then the name still doesn’t change. Then if I check the sequence where I set it up, dynamic naming has been turned off.
This would be such a useful feature if it worked. Has anybody else had issues with this feature?
