Embedding metadata into flame exports?
Afternoon all (or morning/evening etc if you’re a few hours off GMT). Anyone know if and how flame can embed user specified metadata into our exports? Ta muchly if so.
From what I’ve seen in 2022 version it seems limited. There’s another post going on. That might be a crossover with this question that might help!
Metadata for Amazon Prime Delivery
Yeah saw that, but couldn’t quite find my answer in there other than that others are using other software/transcoders to do it. Appreciate you JT x
Maybe @finnjaeger can answer this question? Please oh Oracle?
I fact it would be nice if Flame preserved all the metadata rather than stripping it out. It’s a particular issue here and in fact reared its ugly head again yesterday when exporting an ACES shot for photoshop.
That is top of my Christmas list too.
We have to run our Flame exports thru Nuke to get original metadata in our deliveries.
Same here.
flame metadata handeling is non existant. I also run stuff through nuke to retain metadata.
I have pipeline tools that automatically make dailies from EXR publishes that grab original plates metadata … using nuke.
for random quicktime metadata AMCDX videopatcher is the answere
This one?
It seems open source. Right?
dont think its open source but its free and its great.
make sure you get the latest version, google seems to send people to not the latest
I’ve been having the same issue as well. The people from the DI are compaling that the EXR’s I export to them don’t contain the reel name that’s on the origianl EXR. I did a test to see if there was a differnce within linux vs mac and the linix version shows more metadata on the clip in the directory than the max version. I’m on 2023.1
I need another way to resolve this to deliver these shots without buy Nuke just to do a render.
You can try OIIO
https://openimageio.readthedocs.io/en/latest/oiiotool.html#oiiotool-commands-that-change-the-current-image-metadata
If you have a developer on site, is pretty straight forward to write a script that copies metadata from a source image to the other.
Thank you, but I work from home…
I’ll look at and see.
You can try Gaffer then. The metadata tools a re very similar to Nuke.
https://www.gafferhq.org/download/
You can query, create, modify and copy metadata.
In this case I have modified the reel number and copied a couple more key from one stream to another.
Attached the script if you are up for it.
gaffer_metadata.zip (2.0 KB)
BTW… a bit OT but if you ever need to work with deeps and dont have Nuke… this is it.
I’ll look into this too. Thank you.
I just autodesk would fix this issue. Many people use flame for feature films and episodics. To have the ability to keep metadata when importing and exporting is a big deal.
As a short term help…
Assuming you’ve t-tapped everything and rendered out with correct metadata: what to i like to do is render out exrs with time code as frame number and also /.exr which makes a folder for each shot with the tape name. This works very well for baselight.
Sound good. Just let me know if you need help with Gaffer.
