Hello, via standard Batch expressions, is there a way to determine the Start Frame or first frame of the Batch Group?
Thanks,
Alan
Thanks,
Alan
Not that I have found, and I have looked. Otherwise it would have been built into the fluidmorpher. It’s probably someplace in the ascii file of a saved setup, but the rigamorale of extracting it via some sort of python script is far more difficult and unelegent than just inputing it into a variable node manually. If someone has a better answer, I’d love to hear it.
Same. That’s what I did when I wanted to use your setup in Batch:
The keyword startframe was added to the expressions in the Flame 2017 Update 1 release.
Interesting. When Where can we see that documented.
I wonder what other keywords were added that we are not aware of. Surely “startframe” can’t be the only one.
I don’t believe that refers to setting or identifying the start frame of a batch. Different syntax and different application.
This is awesome, makes things so much easier, but it really should be documented.
Thank you.
