Good morning everyone. Flame 2025.1, in two separate projects, I encounter this amazing thing. Both projects are set up with start frame 1 and so far so good. In batch though, if from action I enter the stabilizer the scene starts from frame 5. There is no way to edit this when it happens which is random though, it doesn’t happen with all shots. Other times, however, it apparently correctly considers frame 1 as first, but does not stabilize the first 5 frames! I am not aware of any settings to change and anyway it has never happened to me before.
does the problem go away after restarting the application?
No it does not…
@Adobox - it might be something to do with the tracker preferences
There is a preference for pre tracking
I can’t remember what it’s called
My prefs always turn this feature off
I’ll take a look in a few moments for the proper verbiage
Oh no it is not that, I never use pretracking so I always keep it off.
Yes I did check that too if it was on by mistake but it is off , I never use pretracking
