Flame 2026.2 – Project Creation Fails on AutoFS Mount (/ProjectServer/projects) Despite Matching Permissions
Hi all,
I’m running into an issue with Flame 2026.2 and Project Sharing that doesn’t seem to line up with the current documentation, and I’m hoping someone else has seen this behaviour.
Setup Overview
We’re using a central Project Server to host all Flame project metadata.
The configuration looks like this:
Project Server
  • Local storage at:
    /<storage>/flame/projects
  • This path is exported over NFS to all workstations.
Workstations
  • AutoFS mounts the Project Server export to:
  • GPFS is mounted locally on each workstation for media and cache paths (matching the same location on the Project Server but exported via NFS).
  • Permissions on both locations are identical:
    • /hosts/<ip>/flame/projects
    • /ProjectServer/projects
Documentation vs. Actual Behaviour
According to the Flame 2026 documentation:
https://help.autodesk.com/view/FLAME/2026/ENU/?guid=project-sharing
Recommended mount paths for shared project metadata and media are:
/mnt/<hostname>/projects
/mnt/<hostname>/media
And the documentation clearly states that /hosts/<host>/… should not be used.
However, Flame only allows project creation using the /hosts/<host>/... path.
When I try to create a project using the correct AutoFS mount at /ProjectServer/projects, Flame fails with this error:
Failed to clone /opt/Autodesk/presets/2026.2/expressions ->
/ProjectServer/projects/Test1/setups/expressions
Everything about the mount is working normally (read/write confirmed, ownership and permissions identical on both paths). The failure seems specific to Flame’s ability to clone the setups directory during project creation.
Questions
Before I file a ticket, I’d like to know:
  1. Has anyone else successfully created projects on a non-/hosts/... AutoFS mount in 2026.x?
  2. Is the 2026 documentation still accurate regarding recommended mount paths?
  3. Is Flame now expecting /hosts/<host>/... even though /ProjectServer/projects is fully writable and mounted correctly?
  4. Is this a known limitation or a regression?
Any insight or examples of working configs would be greatly appreciated.
Thanks!
if you’re copying from a local workstation from /opt/Autodesk/presets/2026.2/expressions
i think this directory is owned by root
and may interfere with your other permissions
what happens if you use wiretap to create projects on ProjectServer?
project creation via command line
it could also be the users in the postgresdb
Thanks for the suggestion, but Wiretap/IFFFS isn’t available on this Project Server setup. The INSTALL_PROJECTSERVER script installs only the minimal services needed for NFS-based project sharing, not the full Flame installation with Wiretap support. So correct me if I’m wrong but I don’t think command-line project creation via Wiretap isn’t an option here.
Regarding the /opt/Autodesk/presets/2026.2/expressions ownership: you’re right, having it owned by root is expected and consistent with our other 2025.X Flame installations. That alone wouldn’t explain the clone failure or why it works fine with the /hosts/ path.
We spent some over zoom with Laurence and he is now up and running using /hosts//
We are investigating why the original mount for the Project server is not behaving the same way as /hosts.
have you found a solve? using /hosts for me caused 5s save times on a empty batch
@finnjaeger we have not yet had the chance to investigate what could be the root cause of the issue. But the moment Laurence modified the workgroup based on our documentation, all was working as expected. But we kept an item in out todo list to better understand the issue.
Keep in mind that his setup was Linux only. In your case, you have Linux and macOS and as we all know, NFS on macOS brings it load of challenges.
its the same if I use linux to linux as soon as i use the default whatever project server does and use “hostip” saving a empty batch takes 5s
Please connect with our Support team since it could be related to many things but we have not seen this with many configurations.
reported this a long time ago in the mids of all these other NFS issues.
same behaviour on 2025 with a project server and no external NFS mounts.. so there is that i have sandbox proven this between even a linux box and a second hardware linux project server.
CaseNo:24619449
it was never figured out, and quiet frankly i do not think my problem was properly understood, or looked at either.
Our Support team will connect with you ASAP to get to the bottom of this since you workgroup seems to have pretty major issues.. For now, please refrain to post on the various threads here to avoid adding confusion and waste cycles. We need to focus on the issues so we can provide solutions.
