Flame 2027.0 Batch Render Different than Source
Hi there. I’m running into an issue where my source is longer than my render. The render says the correct amount of frames. Even while rendering it populates the correct frame count, but then the render is short. This happened to 3 clips out of a ton. Out of the 3 - 2 share a similar setup. I tried re-rendering not using source frames and reimporting the source plate.
Any ideas as to what might be going on/what in my setup might be getting hitched onto?
Don’t think this is it, but do you have step rendering on?
Nope. The value is 1 for step rendering.
Is there a mux with a timing offset that has an inadvertent keyframe?
No muxes in the setup
There is a probably an error message for what happened. Go to the offending Render node, render just that node using Range > Render within the Render node controls (do not use the Render on the left that does everything that is enabled), you will get the error in the little console window in the bottom left (the double up ticks). You probably could even just scrub the timebar to the section that isnt rendering and view the Result of that Render node, good chance it will not display any image due to the same error and you can continue up the node tree until you find the issue.
Beyond that, its hard to say without some screenshots or something more to go on.
Timecode rendering it at a different speed?
Same speed
It gave me an error for every comp node in the batch. I wish I could share a screenshot.
