Flame audio sync cfg setup
I can’t remember if you can change the sync setting in the init.cfg file to from dtv to standalone.
to eliminate the pop up window that asks for sync or freerun.
thanks.
Yes. Just comment out everything under VIDEO PREVIEW DEVICE KEYWORD that has dtvsync in the line.
I think you can also do it with the flame setup app.
If you’re using the GUI in the Setup app, you can right click on the sync type and you’ll get a pop-up with your options.
