Flicker fix
Hi, is there a way to smooth out in-camera flickers/small exposure shifts in Flame?
I’ve used Boris Flicker Fixer for this in the past on other platforms, so thinking of something along those lines if possible
Thanks in advance!
Mux hold your desired exposure source frame, blur that hold frame linked to another blur on your source clip, subtract the the two blurred results from each other and add the result of the subtraction to the original (unblurred) source.
Down and dirty but can get you in the ballpark.
Down and dirty is fine with me! I’ll give it a go, thanks!
Yeah that works a treat, thank you again!
