Frameio Export comments
Hi,
Anyone know how to export all the comments from multiple clips at once on Frame.io
Chatgpt is sending me on a wild goose chase.
try that button, not that it works for me , it just triggers a error :smiley:
@johnag Not sure if this will help you or not, but I started working on a V4 Teams Version of my FrameIO scripts. I’ve hit the wall because we have an Enterprise account, so I’m not able to thoroughly test these, but the Enterprise version works well.
If you’re interested, I’d start with having an LLM analyze these scripts and asking it to help you obtain the access codes/tokens you need. If you’re able to get it to work, it’ll grab comments from FrameIO and add them to your selected sequences.
frame_io_teams.zip (57.2 KB)
Thanks @john-geehreng I managed to export each clips comments into a csv and used the framio script you wrote to import into flame. Worked a treat.
It would be good if it were possible to be able to direct the import to put the marker in as segment marker instead of timeline marker so that the comment stayed glued to the clip
To be fair, it was @andymilkis who started the script. I just gave it a few minor updates.
Double check, but I think that functionality is already there if you right click some timeline segments.
I found it. Its in the context menu for the timeline
