FrameIO & Flame
Hi Everybody,
I’ve been working on some scripts for our team and thought I’d share them now that they are working well for us. Once the scripts are working, you can:
  • upload to FrameIO w/out leaving Flame.
  • automatically version stack when uploading.
  • automatically create FrameIO projects based on the nickname of your project.
  • retrieve comments directly from FrameIO without having to download a csv.
I’ve also made an update to the FrameIO .csv script that @andymilkis started. That being said, there’s a lot of legwork that needs to be done in order to get the scripts up and running. There are 14 required steps and 3 optional ones. It’s all pretty easy, but will take an hour or two. I believe you also need an Enterprise FrameIO Account. We’ve tested it in 2023.2. If you’re still interested, I have more info, scripts, and required modules here.
Let me know here if you all have any questions.
Wow! Thanks so much, John!
You’ve done some serious homework there. Thanks @john-geehreng
Drake Reaction GIF by DJ Khaled
I’ve made some updates to a couple of scripts and added two more to the Logik Portal.
New scripts: Get Status and Set Status
These are self explanatory, but are limited to 2025.1 and higher because I’m using color coding like this because it’s similar to FrameIO color coding:
Updates:
conform uploader
  • Automatically versions up a timeline if there’s a version with the same name already on FrameIO - assumes there’s a v## or V##.
  • Upload Progress Bar
  • Simplified the dumb way I was searching for a shared library
get comments
  • Started using the color coding above but it’ll still work with versions below 2025.1.
Edit - There’s no need to update the config file if you’ve already done that. If you haven’t, there’s a pdf that explains where to get the info the config file will need.
@john-geehreng - color coding and tags make flame better
The new FrameIO V4 API is not open to the public anymore only for enterprise customers…
so thats great … /not
For any brave souls with FrameIO V4 and an Enterprise account, I had Google Labs’ Jules clean up this code and update it for V4. It took about 2 hours and looks like it works, but I haven’t made the switch to V4, so this is UNTESTED, but maybe it will work. It also generated a pretty good Readme:
You are such a good human.
Those scripts are amazing. Will they work on non enterprise frame.io accounts?
no , you dont get Api access if you arent on enterprise..
thanks adobe for that
Is that final? We discussed this before - and for a while it seemed that V4 API access was still in beta, but could be released more widely.
We finally switched to V4, so I just uploaded the V4 updates to the LogikPortal. There’s a new option for “Create Share Link” that’s a nice time saver. In their current state, they will only work for Enterprise accounts.
I have a Teams Version in the works and I’m pretty sure Teams accounts have API access. However, I am unable to test it, so they’re not Portal worthy. Getting the right tokens, client_id, scopes, etc. is far more complicated than the Enterprise requirements. DM me if you’re still interested. Any decent LLM should be able to guide you in getting what you need.
Just to add to that, but maybe you already know this, Frame IO Drive now can directly create a virtual drive on your mac that very, very useful for ingesting assets inside all softwares ! Tested on Resolve, Premiere and shortly in flame. I will try to investigate more the script with API thrue a Teams account soon.
Cool. Here’s the Team’s version if/when you feel like testing it.
frame_io_teams.zip (55.5 KB)
I’ve done a small test ingesting into Flame from Frameio drive. It works well but scary to have any client having access to that drive as well.
and they are discontinuing their frameIO transfer tool and replacing it with drive btw.
Normally only people with access rights ? you can manage all the access (accounts and folders) from the admin panel.
