How to export QuickTime using cached proxies?
Dear friends,
I’ve got a question here.
I’m currently working on a short film that’s about 20 minutes long — something I’ve never done before. I’ve always worked on commercial projects that are usually no more than 2 minutes.
To make handling the material easier inside Flame, I imported everything and generated a 50% proxy cache. I’ve been doing all the conform and review work this way.
Now I need to export QuickTimes for review, but they don’t need to be full resolution.
So I was wondering — is there a way to export using the existing proxies?
In other words, can I export a QuickTime file using the cached proxy media instead of the full-res files?
Thanks a lot!
Well, proxies or not, you can export at half res. Do you want to export using proxies because it may be faster?
You can “extract proxies” and then export those.
Thanks, Sinan and Julio!
What I’m trying to do is take advantage of the timeline render that’s already cached at 50% proxy resolution and export directly from that, without having to reprocess everything at full res.
It seems that when exporting a timeline, Flame automatically re-renders it at full resolution. I know I could export at a reduced scale, but that still takes extra time and storage space.
I’d love to hear more about best practices for working with long-form projects.
Thanks again!
The “Proxy Extract” is the solution. Thanks, Julio!
I thought that applying Proxy Extract to an edited sequence would split it into multiple clips — but it doesn’t. It actually merges everything into a single clip very quickly.
