Importing Maya FBX cams to Action
I have an FBX cam from Maya that isn’t importing into Action correctly. I’ve messed with unit scale, etc. and no dice. Other cams in this project do work.
The cam comes in with just rotation data, no xyz movement.
*It does work properly in Nuke.
Any thoughts?
FBX can be finicky depending on the version. Try changing the the FBX version in the Maya exporter… try 2014-2016?
export a alembic from nuke ? :rofl:
Not like you would expect maya and flame to work together they are different companies after all… and adsk has not invented FBX… oh wait
