In and out in batch render
Is there any way to set or modify the In and Out in the render node of batch? I need to render my shots with handle. I only want to look at the shot without handle.
When I setup the batch from the timeline the Render node got the In and Out set in.
Can we set those manually?
thank you
t-click your source node with ins and outs and it should carry through with your Render node.
Then set your Player to From Marks and that should be it, right? Away from Flame so buttons/names are a probably wrong.
oh yeah that would work t-click.
Thanks
