Looking for help with burn
Hi friends,
I’m trying to set up a burn node. I have a 2nd machine. Burn is installed on it. I can see it on my network. I can see it in Backburner monitor. I can submit jobs to it from Flame on my main machine, but the jobs don’t start.
Any ideas?
Thx!
Couple of things to double check…
On your Flame you ran backburnerConfig, oui? And answered…
Y
Y
< Flames IP address >
And on your Burn 1 you ran backburnerConfig, oui? And answered…
Y
Y
< your Burn 1 IP address >
And if you installed Burn whilst a monitor was attached, make sure that:
opt/Autodesk/cfg/env.cfg
…is set to 0, not 1.
Well @andymilkis, you’ve been burned. I’m sorry. It was just begging to be said.
Problem solved! I had a Mount point misspelled on the burn node. Burning away pleasantly now! :clap:t2::fire::clap:t2::fire::+1:t2::fire:
